Getting a Not Enough Memory Error (solved)
IceDragonArt
So, I am downloading files manually and I keep getting a not enough memory to complete the operation. Which is completley false. I've got over TB of memory in the drive I'm downloading it too- over 900 GB on my C and D drive internally and my dragon center shows I am using far less than 50%. I don't understand why its doing this...
...is it an external drive?
It is. But I was just coming back to say I figured it out. I had to right click on computer, go to properties, advanced and change the allocation of memory from none to system managed. Pretty sure this is something those idiots at Microsoft did with the last update as I have never had an issue with this before this last update.
...W10?
Windows 7, Windows 8, Windows 10 and even Vista have system managed swap by default. A Windows update would never remove a system managed swap space as you'd get odd failures such as the once you got. Someone or some app/utilly changed it from the default of system managed to none.
Also, unless you have like 32GB or more of RAM DAZ Studio iRay renders of complex scenes wouldn't work out too well as they heavily use Windows swap space.
