Poser Pro 2014 Thumbnails - DAZ Installer - ???
LukeAhearn
Hi all,
I worked on this for quite some time - ran the RSR to PNG converter, checked my paths, made sure the PNG files were there, etc...
When I install content from the DAZ 3D Install Manager (which I love!!!) into Poser Pro 2014 there are no thumbnails for my content in the newly created runtime. I really spent a lot of time on this and can't figure it out. I would appreciate help getting my thumbnails to appear.
LukeA
What is the path to the runtime? Is it possible there's a runtime inside another runtime?
I used the default path which is something like users/public/documents... I am not at my computer but that is one of the things I checked. Thanks for the reply.
Ok this is the path.
C:/Users/Public/Documents/My DAZ 3D Library/
Thanks again! :)
And you made sure that that is the exact path used in PP2014? Are the products showing with no thumbnail, or not showing at all?
The products are there and can be loaded, just the thumbnails don't show. I even checked to make sure the pngs are there and can be opened and looked at outside of Poser.
And this happens even with items that come with .png's?
Ok it kind of fixed itself. Weird because I didn't do anything but rename it and start Poser then close Poser and change the name back and it worked, must of needed to reread the thumbs.
OK now how do I delete a library entry!? Driving me nuts that I can add a runtime but can't remove it.
To delete a library in Poser, select the library you want to delete rather than leaving it on . You'll then get another icon with a minus sign next to the add a library icon.
That never worked for me. I ended up re installing poser, too 5 minutes with the new manager, and that fixed it.
Thanks everyone.
