Show us your 3Delight renders
Adding to Cart…
Could be, I'll dig into it, that's not how Stomemason intended it to look like, I'm sure;)
Tks1
Awesome=)))
aweSurface/IBLM render + some postwork
Some male eye candy.
You could check if your figure does have its cornea bulge morph dialed in or not. Default eye shapes don't pick up reflections that well.
Tks!
Nice skin!
Tks have to try that:)
I think it was loop. But my 4.10 actually has refused to load for a while, so I've been only using the 4.11 beta and it looks like they've changed things around again - because both loop and bilinear export as PointPolygons, but now Cat* modes do respond to vertex-only displacement. I'll show something in the next post.
Hmmm, in my experience there is none. In the render, I mean; "view subd level" will certainly change the look in the viewport, and that's that.
Maybe I have a very limited set of HD morphs, but here's the original Genesis with Aging Morphs HD (my original copy of non-HD aging morphs is from Rendo, but Zev0 said they should be identical to the DAZ store version, so even if they somehow depend on the non-HD ones, they shouldn't be broken in any way).
I dialed different combinations (view 2, render 0 and 5, and also view 0 render 0). They all render identical and produce identical RIB files when exported.
Would be cool if you found those HD morphs that do render differently and showed us.
So, this is the difference between classical 3Delight displacement and vertex (mesh vertices only) displacement on a subdivided sphere (Catmark).
The renders that look identical were made for different "render subdivision levels". So it does not make any difference; you can go to render 5, and it's still the same.
...the displacement map is a random old black and white photo actually.
This ugly guy is Walker HD for Genesis1, IIRC this was at subD level 2, I'll do a test render;)
Darn, you're right (as always
) amazing that you can work with something many years and you only see what you want to see, not what's actually happening
Yeah subD1 or 4, makes no difference in render, just slows down your viewport a lot.
Hehe thanks =P I do think there are times when I've been wrong...
I do have Urban Sprawl 2, so I can check what's happening on that render.
It seems the decal parts actually 'hovers' by a lot to the actual road surface. You could fix it the by moving the problematic surfaces to 'stick' to the road plus turning off 'Occlusion & Indirect Light' and 'Shadows' visibility so they don't cast shadows or contribute to GI.
I couldn't reproduce that 'black line' across though. It could be something specific with your lighting setup. I'm just using a HDRI with an environment sphere with just AWE Surface defaults.
Cornea bulge is essential to getting highlights from eyes. I do wish DAZ was more consistent in how the pupil, iris, cornea and eye surface/reflection, tears zone are built though. Settings will vary depending from figure to figure.
Hmm maybe that's why I,ve used 1.59 IOR for the eyesurface/cornea all these years
Cornea bulge is one of the first things I dial in when I add a character.
If I put an object or area light in the line of sight, it will be reflected. It's getting a reflection from the environment HDR that I'm having problems with.
Good point!
Tks for trying! I'm starting to suspect it was because of the motion blur? I moved the whole city to keep the bike in focus and blur the environment. I've used this technique many times before, but maybe something went south? I'll do a test without the MB! Btw, my scene was also lit by an HDRI, except I made some LEDs emissive.
UPDATE: Well it's not motion blur, turned it off and the line is still there. I'm now rendering a series of tests trying different camera angles.
And I forgot to mention I had an emissive light disc for the bike headlight too.
I'll post my findings in the test thread;)
Someone somewhere asked some questions about Grim, you remember him? Nice fella=) Had to (literally) dig him up:)
Chevybabe
Could it be the HDRI then? Too low in dynamic range, for example.
In terms of free HDRI maps, HDRIHaven generally has beautifully dynamic maps - but in my experience, you often need to resave their *.hdr files as *.exr (Picturenaut works for that) for tdlmake to process it properly.
I have a confession to make
Just the other night I found a totally new (for me) ligh intensity slider. You select the environment light node and under parameters/general there it is=))) Defaults at 100, when you raise it to 150 things really start to happen! I feel dumb haha!
That is one of the more horrible things I have seen, iray or 3dl! Well done :)
Thank you so much that made my day:)
...girls girls girls...
...and even more girls...
There's still a few flaws with this one, but as I've spent the better part of 24 hours messing with it I'll just let it lie as it is. These awe shaders breath new life into all sorts of older stuff.
@timeoff
I really like that! The scars and wounds are a nice touch too. Yeah I've noticed the thing about aweSurface too
There's also the exposure slider in a number of places... and the tonemapping controls =D
I never implemented exposure-styled controls in my stuff because I'm paranoid about the pow() operator (old coding habits die hard), but, well, it's there in aweStuff, so why not use it =)
Same for tonemapping... I personally go the "easy route" (EXR -> GIMP running Nik Tools), but since Wowie hasn't put out the EXR script yet... // I need to talk to him about it //
And BTW, do you remember Wowie mentioning in the documentation that it's possible to be using multiple aweEnvironment Spheres set visible to a specific ray type each? This is how you can have the HDR do the diffuse lighting at one intensity (sphere invisible to reflections and refractions) and reflections at another (sphere invisible to diffuse rays). It's an artistic trick, but it's there.
Looks nice, if a little too dark maybe?
Folks, don't be afraid of cranking the lights up more =)
I'm trying to figure out how to make best use of all those=) Endless possibilities..
Thanks I'm aware of that;)
Now that two of you have mentioned it, I felt obliged to take a look and (surprise surprise!!) there really is another intensity control! I had never bothered looking at Parameters/General for the environment light. I had always just gone directly to Parameters/Light. Oh well, no excuses for any more dark renders...
