Is the skirt in the Venom Blade Fantasy Outfit separate?
https://www.daz3d.com/venom-blade-fantasy-outfit-for-genesis-8-female-s
Can the skirt be hidden or separated from the bustier?
  • JessaiiJessaii Posts: 845
    It loads as one piece but there are on/off presets
    425 x 302 - 75K
  • FlortaleFlortale Posts: 611
    edited October 2018
    Do you know if it hides the skirt via transparency or removes the actual skirt geometry?
    Post edited by Flortale on
    Its via setting cutout opacity to 0.00 on the selected parts
    Too bad because that takes up extra video card memory, unless the daz iray render does some kind of trick.
    Thanks for the help though.
