Is the skirt in the Venom Blade Fantasy Outfit separate?
in The Commons
https://www.daz3d.com/venom-blade-fantasy-outfit-for-genesis-8-female-s
Can the skirt be hidden or separated from the bustier?
It loads as one piece but there are on/off presets
Do you know if it hides the skirt via transparency or removes the actual skirt geometry?
Its via setting cutout opacity to 0.00 on the selected parts
Too bad because that takes up extra video card memory, unless the daz iray render does some kind of trick.
Thanks for the help though.
