Thoughts on Terradome 3
Was considering picking up Terradome 3 while it's on sale. Any thoughts on how that compares to making landscapes and atmospheres in Carrara? Does this render quickly enough that it could be used in animations? Would the product function in Carrara at all? How is the quality compared to carrara?
It's marketed as being for Iray, don't know how well it would work in Carrara. You could always purchase it, then try it straight away and if it does not work satisfactorily you could "return" it and get your money back while the 30 day period is still valid. I purchased Terradome 1 when it was on sale, have used it a few times, but use terrains from Bryce far more often.
EDIT: Don't do much animation, hopefully someone else will be able to give some advice on the animation side of things.
Maybe some infos here > https://www.daz3d.com/forums/discussion/comment/1884471/
Thanks for the replies. Read back through the other forum thread, though that was mostly focused on Terradome 2.
Don't really like the hassle of trying to reutrn things and expect to be busy for next few weeks - but we'll see - maybe worth getting and testing briefly to see if any utility in Carrara or if fast enough to use for those rare times I'd set up animation and render directly in DAZ.
