DAZ 4.6 Popup Animate2 menu doesn't work when Animate2 is out
When the Animate2 window, you take it out of the docked position and just have it floating , and you try to selelct from your aniblock list, it just doesn't work. Seems to only work if the aniMate2 tab is docked like together with the Tmeline tab at the bottom.
But the reason i wanted to undock it is cause when docked , the pop out list window is too small and i have lots of aniblocks and aniblock folders.
Here are the pictures of what i mean
1. First picture is animate2 Window undocked(floating).. i click the animate list button, and it just doesn't work
2. Next picture is when Animate2 window is docked, notice how i have long list of aniblocks but the popout window is so small it's tedious, i can't see all my aniblock(or many of them) at once. that's annoying.
This is a bug.
You may want to use the Content Library. It functions with aniMate2 just as well and is more what people are used to. Even previewing works.
Animate2 was built to be used in Docked mode. I reported this myself and GoFigure said the above. As noted you can just use the content window instead.
