Fresh Install and Getting error messages
So, i jsut did a fresh install and when i try to load G8f Base, I get a error message stating file not found. After my fresh install, I used DIM to install other various products from starter essentials, etc.
LogFile:
That may mean the product was installed with Connect and then removed (or the connect data directory chaned). If you find Genesis Starter Essentials under Products in the Content Library pane or in the Products tab of Smart Content does the right-click menu offer Install or Uninstall?
Genesis starter essentials does offer a Install. Genesis 8 Start Essentials offers a Uninstall
OK, then select the Uninstall option and DS should go back to using the DIM versions (with DIM you have two, male and female, rather than the one in Connect).
