Block figures
Every time I try to load a G3 or G8 figure all I get is block figures. Have just started to try DAZ 4.10
keeps saying stuff is missing . I loaded every that was in the folder content . Any help would be great .
That is symptomativc of missing or misplaced files, probably from the Genesis 3 and Genesis 8 Starter Essentials. How did you install them? Are you using the default diectories in Daz studio and (if relevant) Install Manager?
I loaded them manualy . I put all the content where it was to go. Be nice if this worked like Poser, when you
load it it's there.
Poser and Studio use relative addressing, so if you install your content properly and map its location properly in Studio it will work just like Poser. If you installed manually you probably included the "Content" folder that is in DAZ zips and you shouldn't have (DIM strips it out on install).
Thanks - I been doing it wrong all these times. Everything works now. I'll have to buy a bunch of G8 ladies .
