Jagged Edges On Figure
Hello,
I haven't had this problem in the past, but it seems to be an issue on this render as well as a couple others.  I haven't noticed any pattern between them.  I've tried replacing the character with a new model, added a smoothing modifier and have adjusted with several types of render settings.  All end up like this.
Anyone know what may be the cause of the jagged edges around the figure?  How to fix it?
Thanks!!
  • Tim NTim N Posts: 193
    Have you inadvertantly changed the resolution? (Parameters > General > Mesh Resolution > Resolution Level)
  • Hi Tim N.  I check that, but its all at high.  I've found that upping the pixel filter radius helps, but the I also lose clarity...
