Getting back a figure's Constraints.
HeadwaxHeadwax Posts: 10,452
Hi I'm using K4 as the character in a long series of images.
Somehow or other I have clicked on a pose and stupidly selected the rh button in the pop up window which negates the restraints.
Now I have Mr elastic man.
I wonder if there was anyway of resetting his constraints again?.
In case you wondered, I have the use constraints button 'on'. (the one next to collision detection.)
thanks in advance :)!
    I haven't figure it out. Can you reset the figure in the figure's general tab? What about reloading the figure and re-applying the pose?
  • HeadwaxHeadwax Posts: 10,452
    ahh I am not sure, I think I would have to reset all the joints?
    I have the figure saved but it's a complicated scene and he is a relative size to other elements that must be kept consistent throughout the work, just hope there is an easy way :)
    I know in the General tab for the figure, there's a Zero Pose and a Zero figure. I had just assumed the Zero figure reset it to it's factory settings, so I don't know if your morphs would be lost. Maybe try it in another scene to see if it works first.
  • Salem2007Salem2007 Posts: 513
    Maybe it would work if you checked the Translation/Rotation Min/Max options (under Constraint in the Motion tab) and set the values manually? When I have pose trouble, that's where I go first....
    thanks evil and salem
    I'll go and have a fiddle (like nero) and try out those suggestions :)
    okay I have had my fiddle :)
    Rome burnt down :)
    the zero pose and the zero figure didn't bring the constraints back unfortunately,
    Salem, oh it could be two big a job to set all the mins and max but thank you for the suggestion. I better go and hunt down my spare and hope he hasn't been screwed up as well
    trouble is I have no idea how it happened, I've been doing this too long maybe :)
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,419
    maybe convert all you have done pose wise to nla clips,
    save the universal shader if unique
    then delete K4 and load a new one
    add the nla clips back and shaders
    (I often do this on figures I mess up)
    ah thanks Wendy :)
    it sound like a good idea actually,
    Let you into a secret :) I haven't used NLA clips for a few years. I better go and swat up on them ;)
