Genesis Fantasy Wrap doesn't wrap.
AdrianSAdrianS Posts: 77
edited August 2013 in New Users
I've got the Fantasy Wrap dress for Genesis, but it cannot seem to cope with anything other than a straight up pose with the legs together. What I often want is to drape the front across a leg that is moved forward, yet none of the adjustments are any use for that. There are only 6 morphs available, none of which seem to affect the tails of the dress significantly. The product image in the shop shows the tails blowing in the wind, but I can't achieve anything like that. There are a couple of 'wind' morphs, but they (weirdly) only affect the top of the dress. I'm attaching and image of a render where I would like to morph the dress over the front leg. Here, only a very slight adjustment seems to be needed over the left leg, but nothing seems to do it.
Post edited by AdrianS on
  • CyberDogCyberDog Posts: 232
    If you select different parts of the wrap you can adjust them. In this pic I applied a mesh smoother to avoid the wrap cutting through her thigh. I also selected the pelvis and found sliders for twist bend and side to side. If you expand the figure tree further, you will find adjustments for front and back.
    364 x 538 - 40K
  • AdrianSAdrianS Posts: 77
    Thanks. That's fiddly, and it's easy to distort the clothing, but it does seem to work.
