Change Object's Parent?
DekeDeke Posts: 1,636
Can you change an object's parentage mid-shot in Daz Studio? In animation, can I have an item parented to one character's hand, then as the item is handed to another character have the object parented to the second character's hand?
  • AscaniaAscania Posts: 1,855
    No. But you can use two objects.
  • DekeDeke Posts: 1,636
    Thanks. I was planning that as a work around. I'll adjust the opacity so one dissapears and is replaced by the other.
  • or render two sequences, with the frames up to the pick up done with the prop unparented and those after with it parented.
