Custom texture not showing up in render
I set my custom texture to an object. It shows up in the "Texture shaded" viewport, but not in IRAY render. The problem has to be somewhere in the surface settings, because the original settings was, that the object was set to chrome and was reflective. I am attaching the current surface settings of the object, where the texture is not showing up.
Try lowering or zeroing the Diffuse Overlay Weight - with no mask and at 100% it's covering everything else up.
