How to fit a props on a character?
ale.bersanetti
Hi, i've modeled a bracelet that i would to fit to a genesis 8 character with morphs and it should follow in place the poses with the character. Please, someone tell me how to do, or link me a tutorial, i tried to find one on YT but without success.
Does it line up with the figure as imported?
I put in place the bracelet manually as you can see in the picture, but i can't fit it to the character, when i move it, the bracelet doesn't follows. As you see in the third picture, the bracelet falls on the groud.
But if you just import it doesvit lime up with a zeroed figure? That's pretty much required for making it into an item that can fitted.
Parenting the prop is done in the Scene pane with drag&drop for example to the figures Forearm for example, I highly recommed that. Since it is a simple torus I don't know why this should follow the shape morphs, if it dosn't fit scale it.
Otherwise if this is just an example and you want to know how to do it.. Screenshot 2: better use the Transfer Utility with the figure in default pose. Sceenshot 3: how did you manage to let the bracelet fall to floor you must have set up dForce on that item to do so.
Maybe this little tutorial screen can help.
Thanks for the suggestions, i'll try it.
