Leg length in G3M/F?
in The Commons
Hello -
I noticed that leg length (in Shaping) in Gen3M/F seems to merely scale the entire character. Is there a way to control leg length apart from the character scale, as one is able to do with V4/M4?
Thank you!
I'm pretty sure leg length does make the legs longer - but it's not shrinking anything else, so the figure gets taller overall.
You could raise the leg length and then lower the torso length for longer legs while keeping the height the same or similar or to accentuate the appearance of long legs.
What it seems to do is merely scale the entire figure, rather than just acting on the legs. If that's all it does, it's quite pointless.
Base G3M Legs length 100% + base G3M
Legs Length only scales the legs. This also effects the inner thighs near the crotch, so it makes it look like the crotch is slightly lower.
(edited for type errors)
It certainly doesn't on my machine.
Nor, it appears on Glaseye's; please elaborate further; provide images to show what you mean.
