DIM is horribly designed
in New Users
So just download DIM managed to get logged in right by adding the account twice even though same details as the first one finally it started then the list was populated okay then it automatically starts downloadin nothing i wanted to an area i did not want stuff to download to did not have time to change downloads everything then automatically installs it so i thought i will try to click clear queue does nothing when i click clear queue in the intstalled tab then it stops but now i have a ton of stuff i have to uninstall what on earth was going on, bug or intentional feature?
I believe it is meant to install the application and possibly starter essentials on first run for new accounts (it doesn't do it for me, fortunately). I do appreciate that, especially a systems incrasingly have smaller SSD C: drives and a larger mechanical D: drive for data, that this behaviour is not desirable for veryone and woudl suggest that you open a Technical Support ticket to politely request a review of the behaviour (perhaps it couls ask which drive to use at least), assuming it is doing what it is meant to do in the first place. In the emantime, you can batch seelct everythign in the isntalled tab and click the process queue to clear the lot out, then click the gear icon at top-right to open preferences and in the isntallation tab set the application folder (Program Files equivalent, not specific to DS) at the top then add the content location you wish to use, and set it as the Curent directory, in the main section of the dialogue. Note that if you use non-default directories you will also have to set them in DS itself, most simply by download this script and dragging the fiel into an open Daz Studio Viewport http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start
