Carrara Challenge 42 – PIONEERS – Dedicated to Eric Winemiller - WIP
1678911
  • VIArtsVIArts Posts: 1,523
    Trying to do bruce, but it'll be quick and imperfect
  • DiomedeDiomede Posts: 15,393
    edited September 2018
    You were off to a great start on Bruce Lee during the beginning of the month.  Plenty of time to revive and make a wonderful entry.
    Speaking of going back to the beginning of the month...
    Here is the current version of my woodlands pioneer.  I will be using anything grooves on the tree bark, so the foreground tree does not look right yet.
    For the modeling of the pioneer, see here.  frankenpioneer - https://www.daz3d.com/forums/discussion/comment/3920426/#Comment_3920426
    For rendering the distant background mountains, which render as inserted in the backdrop of the main scene, see here.  Background mountains - https://www.daz3d.com/forums/discussion/comment/3954586/#Comment_3954586
    Now, here is a gathering of elements, including a 'lincoln log' cabin, an iron axe from the period, and a tree being chopped down.  I've populated the foreground with some custom trees and shrubs, and I've made a couple hair holders for some scattered grass.
    Suggestions welcome.  Do you think the closer shot or the further shot works better?
    Scene setup
    Distant shot includes full figure of pioneer and the full girth of the tree to be chopped down.
    Tighter shot focuses more on the cut in the tree
    800 x 600 - 89K
    800 x 600 - 80K
    1879 x 979 - 215K
    Post edited by Diomede on
    And here is a test of anything grooves.  I really like the bark result, but not the tree rings in the cut.  Will experiment with editing the shader loaded in the anything grooves modifier.  I am posting this to the entry page, but might switch out.
    1600 x 1200 - 310K
    Like Water
    terrain tools and Shoestring shaders
    my head hurts from trying to grass up the trrain and keep the beach. in errain shader
    640 x 480 - 212K
    Post edited by VIArts on
  • HeadwaxHeadwax Posts: 10,432
    anything grooves really makesa diferrence aye Diomede ? wonderful bark
    love the idea of the chap on the left LightOfHeaven
    quick last minute stuff  - bit of toon pro - still waiting for the wireframe pro to render - forgot to smooth the balloon oh well
    Image may contain: one or more people and text
    Post edited by Headwax on
    1000 x 1375 - 2M
    sorry doublepost
  • StezzaStezza Posts: 8,798
    Cats and pigs will be forever in his debt ..
    actually the non smoothing of the balloon adds to the overall image... yes
    thank you Stezza, yes we can never have too many pointy bits!
    Carrara, rendsr faster!
    I hope it finishes in time and is okay. I wasn't liking my manual backgrounds, so guss what I did? I chucked them into Valla Alpina.
    resu7lt.
    Shoestring shaders
    1365 x 1024 - 3M
    Post edited by Chohole on
    Re-rendered becase the camera wasn't where i put it
    Martial art awesomeness - excellent shader effect.
    Here is my update to address the chopped area of the tree.  I also took the opportunity to change the hair shader to get more contrast with the background.  The rim light was not enough by itself, in my view.
    1600 x 1200 - 287K
    @Diomode: Did you model that log cabin? Sorry, I missed a lot because i']ve been busy with lots of othesr crap. 8i've wanted a log cabin that doesn't look modern, like you just chopped a bunch of trees and stacked 'em.
    edited October 2018
    Yes, the log cabin is modeled in Carrara.  Very simple (almost don't want to say how simple so people will be impressed  wink.).
    - You really could do this with the primitive cylinders from the top menu, but I modeled the log in the vertex modeler.  I started with a simple cylinder, extracted out the ends, and carved cuts for the "lincoln log" effect.  Very simple UVMap as well.  I did not optimize the UVMap because originally I was going to model more parts (door, window) and have them all share the same map.  Ended up not needing that much of the cabin in the scene so I dropped it.
    - Once I had my base log, I just built the walls of the cabin by duplicating the base model and translated vertical by the diameter of the log.  I had to rotate the second wall by 90 degrees and translate 1/2 the diameter to fit the corners.  The roof is just some angled primitive cubes mussed up with shaders.
    - If you want a cabin that is going to be featured in a scene, you could start with this aproach, but you would want a little variety to the logs which could do with morphs and shaders of the base log.  You might also want some logs of different lengths so you can have a door and a window.
    1629 x 978 - 150K
    1656 x 945 - 193K
    Thanks! I'll work on it as a side project
  • AlbertoAlberto Posts: 1,458
    Entry thread closed
    Voting thread opened
    Great job working our brains, Alberto!
  • ed3Ded3D Posts: 2,508
    edited February 2024
    _  well, Good Night    * ^.^ *
    Post edited by ed3D on
  • Bunyip02Bunyip02 Posts: 9,268
    ed3D said:
    _well, Good Night  _^.^
    Hello ed3D, I was hoping to see your entry in the Challenge, are you still able to show us a final render of where you were up to ? Would love to see it !!!
    There is also the "Post Your Renders - Let's Rock 2018!" that you can post your renders in, and for "Non-Photo-Realistic" renders there is the "Carrara Non Photo Realistic Works"
    Hope to see you joining in !!!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,239
    this is going to be hard to vote on, I am not fond of voting on these things and usually avoid it but since I actually entered should.
    Everything is so excellentyes
    yep.. great to see so many great images.. and so diverse
    thanks @Alberto for your hosting yes
    edited October 2018
    _Well, Thanks Very Much     _ In-complete
    _Title: Not Another Earth Rover/Probe
    1333 x 1000 - 485K
    Thanks for sharing that ed3D!
    Thanks for being a great host Alberto!
    Thank you for participating!
    ed3D said:
    _Well, Thanks Very Much     _the In-complete
    Thanks for showing your work. yes
    Looks like you and Stezza were on the same wavelength - love the cartoon vibes !!!!
    _wasn't really trying to have a cartoon vibe,  But that could be Cool
    Bunyip02, Alberto, evilproducer : you're quite welcome
  • Charlie JudgeCharlie Judge Posts: 13,288
    edited October 2018
    I don't visit the Carrara forum very often and just saw this thread. I am especvially interested in the Ground Control plugin but I don't see anywhere to download the plugins. What am I missing?
    Nevermind. It was kind of hidden but I figured it out
    Post edited by Charlie Judge on
