Low poly and resolution Genesis 8 characters for crowds
Hi there,
I would love see some one create low poly, resolution Genesis 8 characters for making crowds and groups of people. For background movement and animations.
I know Predratron has made a version (which is fairly old now) but I would like to see an updated version so that you can add Genesis 8 aniblocks on top.
Including a simple wardrobe for both men and women.
Thanks
Winton
  • The base Genesis figures are already quite low resolution, if you set the Mesh Resolution parameter to Base. If you want to limit memory use your first target should eb the textures - there are a couple of free scripts for resizing textures, or there's Scene Optimiser https://www.daz3d.com/scene-optimizer
    You can use decimator to reduce mesh and the texture atlas inside DS to combine textures to a single sheet to save on resources.
  • Thanks Richard and FSMCDesgins. This will help alot :)
