Classic van by ansiko
I have a problem with th classic van by ansiko. I can't rotate the complete van because I can only select single parts of it and not the intire van. same problem with the ladybird car. Other vehicles (not from amsiko) work just fine.
  • Check the Scene pane - you should see either a prop to which all the oters are parented or a null node to which they are parented, either way selecting (by clicking in the Scene pane) rotating that should work.
  • Thanks for the reply, it works.
  • Forget my earlier reply if I select the van in the scene pane the scene rotates not the van. if I select other parts of the van in the scene pane they will rotate. All parts seem to be parented to the van but the van itself will not rotate.
  • mcorrmcorr Posts: 1,104
    anybody had luck with changing the colors ... no matter what i do, i cant get them to apply ..
    i got it ... it only works on the generic one, not the special versions, like boulanger, police van, etc.
