To Gamma or Not To Gamma, this is the question
RarethRareth Posts: 1,462
edited August 2013 in Daz Studio Discussion
Ok here we have two Images of the Same Scene, everything is exactly the same except in the render settings one has Gamma correction ON with a Gamma of 2.2 and one has the default setting (Gamma Correction OFF and Gamma of 1)
Top Pic is Gamma ON, Bottom Pic is Gamma OFF
Which do YOU think looks like it has better lighting?
Post edited by Rareth on
  • Richard HaseltineRichard Haseltine Posts: 108,459
    Depends on what you are aiming for - but the first has more tonal smoothness, the second is much more contrasty with sharper transitions.
  • RarethRareth Posts: 1,462
    well I've been reading a lot about light and gamma, and I've been following the Cararra discussion on the Gamma Correction setting.
    So I figured an experiment was in order to see how it would effect a DAZ Studio Render with 3Delight (I have luxus and it defaults to gamma 2.2)
    this scene was just lit with 3 DAZ studio spotlights, no UberEnvironment, no area light planes. I was really intrigued when I saw how different they came out.
    my biggest surprise was how different the background is between the two renders.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,229
    google gamma 2.2 render and see all the results
    as I said on C forum I found 3dsMax has gamma correction of 2.2 as it's default setting.
    I see Facegen has too and iClone so there must be something in it!
    oh I agree, which is why I started playing with it in Studio.
  • RenpatsuRenpatsu Posts: 828
    edited August 2013
    As far as I understood the Daz Studio setting, just setting "Gamma Correction" to "On" already makes DAZ Studio 'guess' what Gamma to use per texture, so bump maps get a 'guessed' Gamma of 1.0 while e.g. diffuse texture maps get 2.2, which is usually how these maps are designed to work. The "Gamma" slider appears to adjust the overall brightness/exposure or so? Not sure if someone from DAZ can chime in and explain how it is correct.
    Post edited by Renpatsu on
    hmm news to me, now I need to do a test with the gamma slider at 1.0 and gamma correction on
    Yes, the Gamma Correction switch is adjusting the maps for their presumed gamma (or you can find them in the Surfaces pane, click to bring up the browse/Layered Image editor/texture list menu and pick Edit Image to set the gamma to use - 0 means guess) while the Gamma slider is for setting the output image's gamma value. Usually if the latter is non-zero you want the former on.
    That is good to know, adding to my word doc I've been compiling all day based on render experiments.
    I am liking the results with Gamma correction ON and the slider at 2.2. especially after adding a smidgen of specular2 to bring out some of the detail.
  • Eustace ScrubbEustace Scrubb Posts: 2,727
    Would a ShaderMixer snippet to adjust gamma at the material/surface level be useful?
  • SotoSoto Posts: 1,450
    I like the top one.
    Seeing both makes me want to put one of top of the other with a 50% opacity. But I think I pick the top one.
    I'm leaning towards the top one myself (Gamma Correction on)
    and with some minor tweaks to shadow softness and specular settings..
    1024 x 768 - 289K
    That's pretty cool, I'll have to experiment with the gamma too and see what happens. :)
  • TakeoKenseiTakeoKensei Posts: 5
    Your last render is better. Without Gamma correction, the renders are darker, espescially shadows
    My opinion is that using Gamma Correction really depends on what you're willing to achieve, but if you're aiming at more realistic renders, it should be ON
    Probably - as far as I can tell the gamma setting applies through out the application, though if set to 0 I think DS guesses by contest. But in Shader Mixer there isn't the same context, so with some networks it may be necessary to set a value for the image and then correct it manually where another value would be needed.
    This was dug up (praise the Lord for the Wayback Machine!) from a lost newsgroup article from '94 called Color Space FAQ, by one David Bourgin.
    Color spaces FAQ - David Bourgin
    Date: 28/9/94 (items 5.2 to 5.10 fully rewritten)
    Last update: 29/6/94
    4 - What is this gamma component?
    An important notion in image processing comes from physical properties of
    output devices. We often have to correct the colors of an image to get a
    better rendering, i.e. to sharpen or blurry the picture. With the monitors,
    this is really true because input signals - proportional to the voltage -
    don't output a linear answer curve. So, a normal monitor follows an answer
    curve with an exponential law and a monitor based on LCDs follows an "S"
    curve with a vicious hook near black and a slow roll-off near white.
    The adapted correction functions are called gamma correction.
    We will keep in mind that most of software propose a displaying correction
    based on a power law relationship. It is given as:
    Red = a*(Red'^gamma)+b
    Green= a*(Green'^gamma)+b
    Blue = a*(Blue'^gamma)+b
    where Red', Green', and Blue' are the values of volts in input, i.e the
    values of each primary component for each pixel in the picture you have,
    Red, Green, and Blue are the adapted light components for your device,
    a and b are linear transformations to adapt the law relationship, and
    gamma is the correction factor.
    Be care: a, b, and gamma are usually real constant for *all* pixels.
    Note that the software set up a to 1 and b to 0...
    For CRTCs gray level drawing pictures, gamma is usually within the range of
    [1.2;1.8] but for true color pictures, the number is usually within the
    range of [1.8;2.2]. Normal display devices have an usual 2.35 (+/- 0.1)
    gamma value.
    I assume in the previous relationships that Red, Green, and Blue are
    given within the range of [0;1]. But if they were as well positive as
    negative, you could have, for *example*:
    Red' = -0.5
    and Red = -(abs(Red')^gamma) = -(0.5^gamma)
    In some image file formats or in graphics applications in general, you
    need sometimes some other kinds of correction. These corrections provide
    some specific processings rather than true gamma correction curves.
    This is often the case, for examples, with the printing devices or
    in animation. In the first case, it is interesting to specify that a color
    must be re-affected in order you get a better rendering, as we see it later
    in CMYK item. In the second case, some animations can need an extra
    component associated to each pixel. This component can be, for example,
    used as a transparency mask. We *improperly* call this extra component
    gamma correction.
    It doesn't sound too difficult to model (says the guy who tried turning displacement maps into normal maps...)
  • MachieltjeMachieltje Posts: 0
    could be my screen but to me the top one looks flat and boring while the bottom one is more vibrant. The third is getting there but still lacks the character of the second. But like I said it could just be my poorly callibrated screen.
    btw art isn't about faithfully reproducing reality; it's about enhancing certain aspects to evoke emotion...
    Just a thought.
  • Scott LivingstonScott Livingston Posts: 4,348
    edited August 2013
    Hmm...I partially agree...first one is more realistic, but the second is more aesthetically pleasing, I'd say. But #3 I definitely like more than either of the others.
    Post edited by Scott Livingston on
