Aniblock ..
Hello guys,
I have a question regarding aniblock, as i'm not a native english speaker it's really hard for me to explain.
I will give an example :
Let say i have 3 consecutive aniblocks 1 is idle, 2 is walk, 3 is run
When i play my sequence there is a "junction" (the end of the block is the begining of the next block) between blocks, and i would like to get them to be independent to each other...
I hope i'm clear enough, and someone will be able to help
thanks !!!
Post edited by tankeratl on
Normally people want the junction that makes it all flow together. If you don't want that, then you can turn of the reorient mechanism. If you click on the 2nd aniBlock, look for the icons that have two small arrows pointing the same direction. Click on the first one and set it to off. You may also want to slide the green below the aniBlock so there is less blend.
There is another way and that is with starts, but that is if you want to chain a couple, then have a broken junction and then chain a few more aniBlocks.
GoFigure,
Thanks for your prompt and clear reply, it works very well. I know usually people want the junction to be done !
Anyway, thanks for anyblock wich is a really great tool !!
