3Delight Error Msg
evilded777evilded777 Posts: 2,485
edited August 2012 in Daz Studio Discussion
3Delight message #45 (Severity 1): S2072: the shader 'E:/Program Files/DAZ 3D/DAZStudio4/shaders/omnifreaker/surface/omShadowSurface.sdl' uses a different interface version. Automatic conversion was successful. It should be recompiled for better performance.
I installed 4.5 32 bit version today for reasons I will note in another thread.
I do not recall seing the above error msg with 4.5 64 bit previous to installing 32 bit. I now get this error msg in both versions while rendering.
I just reinstalled Uberhair, Uberspotlight, Uberpointlight all newest versions for 4.5. Still provoking this error msg.
What might be the culprit?
hhmmmm.....edit: seems to have something to do with the application of HSS. I believe I may have neglected to reinstall an update version of that, its hard to remember what omni products come with the package now.
Post edited by evilded777 on
  • evilded777evilded777 Posts: 2,485
    Ok... so. Incomplete uninstall, or installing some plugin that I did not need to/wrong version of some plugin seems to have been the culprit here.
    But I swear I was not getting that error msg previous to installing only the 32 bit version. Whatever, its fixed and maybe my buffonery will help someone else.
  • Kendall SearsKendall Sears Posts: 2,995
    Don't worry about it. That is just a warning. The shader is for a different version of 3DL and it is just saying that if you recode the shader, it might run faster.
    Kendall
  • Richard HaseltineRichard Haseltine Posts: 108,683
    DAZ Studio 4.5 has a new version of 3Delight, hence not seeing the warning before. As Kendall says, it isn't a bad thing though a proper update might improve performance.
  • SzarkSzark Posts: 10,634
    I am getting this wiith Uber Surafce 2 and Uber Spot lights and yes they are the undated ones. :) Doesn't stop the render so I ignore it. ;)
  • SimonJMSimonJM Posts: 6,073
    Ditto
  • 3delight message #140(Severity 1): R0531: unsupported hit mode 'transparent' wtf is this and how about a directory so we can just look it up?
