Help with my new horse
TrishTrish Posts: 2,625
He was fine till I loaded the mane and tail.......Help please
  • WilmapWilmap Posts: 2,917
    You need to select the tail and mane and add a Material to them.
  • TrishTrish Posts: 2,625
    edited August 2013
    Hi: ok I got it I had to select the whole mane at once .....thank you
    Post edited by Trish on
    Select the mane in the Scene pane first, then select the Material, and double click on it as shown below.
    910 x 864 - 399K
    Jimmy C; so is there anything I can do to fix this tail so it looks better....Thanks Trish
    1054 x 516 - 285K
    Render it, objects with transparency maps applied look weird in preview do to limitations of graphic chips/cards.
    If you select the tails in the Scene pane, and then go to the Parameters pane, you will find Shaping and Movement morphs under 'Actor and 'Pose Controls', they should help a bit. Is that what you mean, or is it something else?
    Thanks Jimmy C. the tail looks good now I appreciate the help
    769 x 769 - 141K
