How do I fix artifacts in my render
Please tell me how to remove this artifact? It appears on every outfit (((
Do you have smoothing set on the skirt?
Post split from a commercial thread.
Select your Clothing Item in the Scene Tab, Open your Parameters tab, using the Mini Menu set it to Show Hidden, Open the Active Morphs. Zero any that are from the Gens and Thighs, this should set the clothing back to the proper shape.
Zev0 Smoothing helped)))
Jaderail the trouble is that this artifact arises in the base figure (((
Thank you for helping to understand)))
You do know that there is NO reason to add the gens if they will not be seen in the final render. The basic figure will work just as well for that type render.
Smoothing helps but is not enough! Developers figures should fix it sticking. otherwise it can be considered a defect shapes!
