find the installed products ... where do they go? and where are the docs?
I've been picking up a few older items with all the sales going on, but , even though they downloaded and installed via DIM, I cannot find them, or cannot find documentation, etc..
1. https://www.daz3d.com/advanced-daz-studio-light-bundle . where are the lights? I cannot find any reference in DIM .. they are not installed i rthink, even though DIM downloaded them and installed them. I cannot find in content or in smart content.
2. https://www.daz3d.com/dforce-master-hair-simulation-presets-for-dforce-cloth-engine i found this in content, but cannot find the documentation anywhere. It would be good to learn how to use it ... just plugging into it is not working at all.
3. https://www.daz3d.com/glute-control-for-genesis-3-female-s i found this in ready to install in DIM, even though when it dowloaded, i watched the install bar get completed, but it did not install.
These are the first of the new things I've tried to use.
  • From the File List for #2, it appears there should be a .pdf located in /ReadMe's/49199_dForce-master—hair-simulation-presets-for-dForce-cloth-engine.pdf
  • davesodaveso Posts: 7,841
    thanks ..found that now. giving it a run.
  • TaozTaoz Posts: 10,271
    edited September 2018
    There are links to individual user guides for each of the products in the bundle, on their respective product pages.
    Go to the "Installed" tab in DIM, if you right click on a product there is a "Show Installed Files..." option, you can find most stuff that way.
    Or did you get an "Install Failed"?
    Post edited by Taoz on
    thanks..on #1 i found the guides now, but cannot find the content.
    They should be here:
    690 x 268 - 26K
    seems easy enough, but they are not.there... I have a render cooking right now so will save it and close when done, and close the program and restart. I dont see it in the installed products in DIM though ... I tried to do the dowenload and install as well and nothing happened. Will probably have to manually install.
    I've had some delay today when trying to download and install with DIM, but after a while it started.
