Genx just doesn't exist.
I just installed GenX. I was going to add the serial number, but I don't see Genesis generation x2 among the plugins, so I can't add the serial number.
I've read other suggestion about adding it from edit/customize and... there is no customize option under edit.
so what should I do?
Did you buy all the plugins you need?
I bought everything
Edit>Customise has been Window>Workspace>Customise for some time now.
Where are you looking for the plug-in to add the serial number - under Help>About Installed Plug-ins? How did you install?
I was looking under help>about installed plugin and it looks just like if I haven't installed anything.
I installed all GenX files through DIM.
And yes. I looked at windows/customize and looked at miscellanous, but I only have the 'Freeze Simulation' option.
Succeded. I had to install it manually.
Did the actual GenX plug-in show in DIM? If it showed only the add-ons for figures it may be that the Download Filters are not set correctly
Genesis Generation X2 for DAZ Studio 4.5+ (Win 64-bit).
And then the add-ons.
OK, if you right-click the entry for the plug-in in the Isntalled tab and select Show Installed files you should get a list of what it installed and to where - and if you click the links it should open that location. Check that the plug-in (the .dll file) did go to your plugins folder in your 64 bit Daz studio application folder (or a sub-folder), and that the file is really there.
