RW Wood Nymph for Genesis 2 Female(s) Texture Issue
fledermausmannfledermausmann Posts: 10
Hi all,
I just got the above product [RW Wood Nymph for Genesis 2 Female(s)] and no matter how I try to load the textures, it seems they're not mapping correctly or something.  Here's a screenshot:
No difference if I choose Default UVs or Wood Nymph UV Set, and I even tried exporting the textures and flipping them around to see if something was backwards or whatnot but nothing looked any better.  I also tried playing with the Offsets and Tiling to no avail.  It's only affecting the two highlighted surfaces, "Perch_Large" and "Perch_Small"; the Dress texture looks fine.  Wondering if anyone has any other ideas...thanks
  • Moved to Technical Help as it's a question, not a Product Suggestion. Also edited to add the product name to the body of the post.
    Are you sure you are using the correct materials? Does it look wrong in renders as well?
  • Yes, it does look wrong in the renders as well.  I'm not doing anything abnormal to apply the materials, just load the product then load the product materials, as usual.  Can anyone else replicate this?  Or is there a way to contact the vendor?
  • LeanaLeana Posts: 12,827
    DAZ handles the support for products, so you would need to open a support ticket, not contact the vendor.
    (I don't have the product so I can't help, sorry)
  • All right thanks, I'll open a support ticket.
