Probably old topic but can't find: G3F morphs to G3M?
Ptrope
Title says it all - is this possible? Back in the old days of Genesis, it didn't matter, but then we decided once again to make 2 different meshes, and a program just smart enough to tell us, "Hey, you can't add that morph to this character." I've tried Googling the topic, and I see plenty for copying morphs from G3F to G8F, but not to G3M (or vice versa, either), which seems like it would be a closer fit. I also see several mentions of a Transfer Utility, but can't find any details of what it is, where it is, if it's part of the Studio 9using 4.10 Pro) or a separate tool. And again, Googling doesn't seem to bring up any answers, just discussions that say, "Hey, use the TU!"
I would if I could find it!
Well, the polycount is different between G3F and G3M. Earlier, not so much, but they started adjusting the mesh between the genders with G3.
You can use Generation X2 to copy morphs between Genesis 3 male and female. You need the main plug-in and two add ons as follows:
https://www.daz3d.com/genesis-generation-x2
https://www.daz3d.com/genx2-addon-for-genesis-2
https://www.daz3d.com/genx2-addon-for-genesis-3
You can also use this to move any morphs from Genesis 1-3 between each other, plus morphs from M4 and V4. You can not use it for Genesis 8.
