Running both Kepler and Maxwell Nvidia Titan's in the same machine
Apologies if this has been asked already - but is it possible to use a Kepler 6GB Titan Black with a Maxwell 12GB Titan Black and have Iray use both cards?
Thanks
Thanks
I don't know for sure, but I believe you will be limited to 6GB on both cards.
Weel from what I've read it seems that if the cards both work as expected a scene that fits in the lower menory amount with run on both cards - if it exceeds the lower but not the higher it will just run on that card - and if it exceeds that it will render CPU only
