Daz Horse 2 isn't loading.
BCManBCMan Posts: 17
Here is my problem.
I just purchased Daz Horse 2 last night and tried loading it and got this message in pic # 1
and after having no option but to push OK I get this in pic # 2 even though I have texture shaded clicked
I use Win7 and DAZ 4.6 Pro 32 bit
my computer is fairly high end.
I even checked a few of the threads regarding the dsf vs duf files
and went to Edit - Preferences - Starteup to check and yes it's set to use the duf files (pic # 3).
At this point I don't know what to do,
can anyone help?
  • fixmypcmikefixmypcmike Posts: 19,707
    Did you install it with DAZ 3D Install Manager, or manually extracting from the zip? If you used DIM, can you post these two screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • Richard HaseltineRichard Haseltine Posts: 108,998
    Your start up scene is Genesis, not the horse, so that isn't relevant. How did you load the horse?
  • cm152335cm152335 Posts: 421
    Problem is the "Content" or "My library"
    Inside those folder you found Data - people - runtime,, etc,,
    Just copy the folder found in content (data-people-runtime) and not the main "content"
    Another use is to create a new library in your hard disk and target is the "CONTENT" when the program ask you to define a new runtime folder.
