Running both Kepler and Maxwell Nvidia Titan's in the same machine
Apologies if this has been asked already - but is it possible to use a Kepler 6GB Titan Black with a Maxwell 12GB Titan Black and have Iray use both cards?
Thanks
  • KitsumoKitsumo Posts: 1,222
    I don't have those particular cards, but I ran a Pascal, Fermi and whatever the 770 is without any problems.
  • I don't know for sure, but I believe you will be limited to 6GB on both cards.
  • Weel from what I've read it seems that if the cards both work as expected a scene that fits in the lower menory amount with run on both cards - if it exceeds the lower but not the higher it will just run on that card - and if it exceeds that it will render CPU only
