Seamless tiles not seamless
SylvanSylvan Posts: 2,719
I am trying to retexture a prop with a seamless tile, but the pattern doesn't show seamless. What am I doing wrong?
Post edited by Sylvan on
  • Oso3DOso3D Posts: 15,119
    For it to be seamless the UV has to mesh/wrap properly.
    If it's some random prop, there's a high likelihood it doesn't.
    To get around that you can either use a procedurally generated shader (like my OMS1) or use an Iray decal and use it with a projection rather than UV (cylindrical projection would be the obvious choice).
    A final option is to redo the UV map, but that might require applications you don't have.
  • Richard HaseltineRichard Haseltine Posts: 111,471
    edited September 2018
    So that's a single surface and the image is set to tile twice?
  • Maybe the pattern you're using is seamless, but there's not a whole number of tiles wrapping round the cylinder - say one tile covers a square metre, but the circumference of the cylinder is 1.5 metres. You'll only get one and a half tiles wrapping round the cylinder, giving you the ugly seam.
    One way to fix that is to adjust the Vertical Tiles and Horizontal Tiles parameters of the surface, which will make the stripes bigger or smaller, but can also make them join neatly.
  • XyetztXyetzt Posts: 27,554
    That is cool!  Oh not wanted but cool effect.  Prop is not mapped to be seamless with seamless image map.  Unless mapped that way it requires some seam work to be seamless.
  • pwiecekpwiecek Posts: 1,598
    Seamless texturesare designed to be seamless when you use multiple copies end to end. If you want a seamless join on your prop, you have to create a texture specifically for it.
    Post edited by pwiecek on
  • SylvanSylvan Posts: 2,719
    Thanks everyone! Yes I tried several tiling settings but they don't match up. I think I indeed will have to texture it by hand. Oh well, so much for the (lazy) easy way!
  • "Seamless" just means that the edges match left-to-right and top-to-bottom, if your mapping uses only a portion of the image or if you have a non-integer repeat then the pattern will show the join.
    Yep.
    The problem isn't the texture, its the cylinder. I'm using a cylinder from poser so the details may be different.
    If you look at the UV map of the cylinder, it looks like this:
    1024 x 1024 - 152K
    If you apply a generic texture, it will cover the UV map like this:
    1024 x 1024 - 154K
    In order to get the seam right on the cylinder, you have to adjust the texture to fit the UV map. I repeater the texture 3 times.
    1024 x 1024 - 147K
    There is still a part of the map that is not textured. Rather than add another copy of the texture, which would break the seam again, I stretched the existing texture to fill the UV map
    You still need to figure out something to do with the top & bottom.
    1024 x 1024 - 439K
    You're awesome! Thanks for the explanation, it now sounds so logic. Off to fiddle with the textures =>>>>
    If it's a quare tile & it's a cylinder don't your need to repeat the tile PI times (3.14...) to mostly avoid the seams or not?
  • If it's a quare tile & it's a cylinder don't your need to repeat the tile PI times (3.14...) to mostly avoid the seams or not?
    No, the tiling is just a surface property, it doesn't care what 3D shape the surface is wrapped around. You may well need different values for horizontal and vertical tiling to keep the pattern square, however.
    It stretches to fit
