Genesis 3 / Genesis 8 to Mixamo - Tutorial
Hi everyone,
There are a few bits and pieces online, but I've not found a simple guide to uploading Genesis 3 & 8 to Mixamo, so here is what works for me (Note - If you have a better workflow, let me know and I'll add it!)
1. Open your figure in Daz3d. For Genesis 8, Adjust your figure to a T-pose (Left shoulder: Bend, 45.61, Right shoulder: Bend, -45.61, Left Thigh: Side-side, -6, Right Thigh: Side-side, 6)
2. Clothe your figure (Some hair on Genesis 8 makes the Mixamo auto-rigger fail. Genesis 3 is generally OK)
3. Unparent ALL hair & clothes & convert to props.
4. Convert figure to prop.
5. Re-parent all hair & clothes to figure.
6. Export as FBX with the options as in the screenshot.
7. Upload to Mixamo!
  • wolf359wolf359 Posts: 3,942
    Hi
    If indeed your final objective is to use the Mixamo animations on genesis 3/8 there is a much easier alternative.
    If you do not have genesis 1 install it from the DIM
    Upload the default nude, Original genesis 1 figure to Mixamo.
    apply the animation of your choice and download the Motion data.
    Apply motion to genesis 1  in Daz studio, and save as Pose preset(.duf) saving all frames
    Load G3/8
    Apply that animated pose preset to G3/8...it will work
    See details for dealing with the G8 "A-pose" in this thread
    https://www.daz3d.com/forums/discussion/comment/3675321/
  • I got Genesis 8 to Mixamo by deleting the eyelashes and changing the export setting to FBX 2014-Binary.
  • wolf359 said:
    Hi
    Load G3/8
    wolf359 said:
    Hi
    Load G3/8
    Can you please go on detail for every step of the way? I tried doing that but i have no idea thow to save the motion data. FBX exported from Mixamo cant load into DAZ, Tons of errors.
  • EightiesIsEnoughEightiesIsEnough Posts: 1,247
    edited January 2020
    I tried to upload a G3F to Mixamo using the method in the original post (though I couldn't find the convert to prop function for converting a dress and hair to a prop), and I got this message:
    What can I do to fix this problem?  Is this a flaw with the 4.12 version of DAZ?
    I noticed the previous posts in this thread were from September 2018, February 2019, and September 2019 respectively.  Hmmm...
    Post edited by EightiesIsEnough on
  • verrrosverrros Posts: 0
    How exactly? I tried multiple times but either it says that it could not map existing skeleton or It processes but i cannot see my character at all for mapping..
  • edited April 2020
    Search YouTube "Importar DAZ Genesis 3 a Mixamo .FBX 2020 Funcionando 100%"
    I have a video there explaining how to do it, good luck friend
    https://youtu.be/1ocACSQ7pt0
    Post edited by cuervo357_d59b8f75de on
  • rachr0rachr0 Posts: 0
    Está privado ¿Cómo lo veo?
  • avtodimifavtodimif Posts: 0
    wolf359 said:
    Hi
    Load G3/8
    This method doesn't work, its possible but root of the Gen3 have different offset along the animation....
  • Hi everyone,
    I can confirm this method work with genesis 8, convert all figures to props (hair, sunglasses, dress, hair, genesis 8) then export to fbx and upload, mixamo will launch the auto-rigger tool, after that your model is ready.
  • EightiesIsEnough, to convert to prop go to the drop down menu for edit. Then to figure, then to rigging, then convert to prop.
    I have been struggling with this for a while now and I am going to try the convert to prop method and see how it goes.
  • Hi everyone,
    I've noticed you have to convert most of the wearables to prop before you will detach them from the figure and before you will convert main figure to prop. Then re-attach them. Rest works fine.
  • Revisiting this thread... I did successfully upload a fully-clothed character as a prop for Genesis 3, but I got a problem.  When I export as a FBX Binary and import it, the animated character doesn't appear in DAZ Studio.  When I export as an FBX Ascii and import it into DAZ Studio, the figure appears but with no animation.  What should I do to fix this?
  • stellar.elitestellar.elite Posts: 2
    edited August 2021
    I have the same problem. I'm using Genesis 8 and I've tried everything in this thread and nothing works. Either mixamo complains about the skeleton map or it lets you past that stage and then presents you with a blank grey screen and no effing model to put markers on.
    Post edited by stellar.elite on
    I seem to be having the same issue. I successfully downloaded fbx files from mixamo and when i imported the files into daz studio for putting different animations together (from T-pose to animation for marvelous designer) the figure appears but with no animation. Does anybody know a solution to this problem? Thanks
    776 x 846 - 266K
  • Causam3DCausam3D Posts: 216
    wolf359 said:
    Hi
    Load G3/8
    Pretty much just unadulterated freakin awesomeness!  Yes, this works.  Very well.  Thanks!  Saved me a lot grief.
  • Causam said:
    wolf359 said:
    Hi
    Load G3/8
    Don't the fingers come out weird when you do that mine do?
  • Causam said:
    wolf359 said:
    Hi
    Load G3/8
  • catmastercatmaster Posts: 226
    edited September 2022
    Building an Animation with Mixamo and Genesis 8 Figures
    Post edited by catmaster on
