Lights Inside Buildings
Hi, I just installed the Old West Sheriffs Office and Old West Saloon and I want to put a light inside the building so when looking at the building from the outside it will look like there is a light on inside the building.
I have tried all the different lights but I don't see the lights inside the buildings.
I am sure I should be able to do this but I just can't figure it out.
How do I do this?
Thanks for the help !
  • barbultbarbult Posts: 26,423
    Are the building window materials opaque and blocking your light?
  • What are you rendering in? Iray or 3Delight? If you are using the standard lights (spotlight, point light, etc) you need to set the lumens a lot higher than you would think to get any good light. For Iray, Try increasing the lumens to 100k and see what happens.
  • FishtalesFishtales Posts: 6,218
    I did a series of test renders putting lights into a building to test render times. I posted the results here with the light settings used.
    https://www.daz3d.com/forums/discussion/comment/2904886/#Comment_2904886
  • Thanks everybody. I had to turn up lumens a lot and windows opaciy to zero. All your info got everything working the way I wanted. Thanks again everybody !!!!
