Demon tails for G8M
Noah LGP
Hi,
I'm looking for demon tails similar to these products :
- Incubus Tail from Dark Fantasy Add-Ons for Genesis 3 Male(s)
- Tail from Tara 2 HD for Victoria 7 & Victoria 8
Post edited by Noah LGP on
/Agreed!
DYING to do a Nightcrsawler and I will have enough problem with his feet and hands alone, much less making my own tail too!
Would also like to see tails long enough to wrap around body and lay on the ground
https://www.daz3d.com/dark-fantasy-add-ons-for-genesis-3-male-s That tail connects quite well to the G8M figure. I use it myself on Michael 7 and 8.
@RKane_1 I used the g3m tail from that same set to make an Azazel model. I am sure it could be easily modified and retextured to be Nightcrawlers.
Thanks, Linton. I wound up using Easy Pose Tail for G3M modified to work with G8M. It also updates wellI may have to check out the item yuou posted as it has the wings as well. Have you tried using those on G8M yet? If so, did they do well?
