Is there any poses for zombies climbing out of ground?
JENR8
Do you know if there is a pose for a zombie being unearthed or halfway from the grave - torso exposed.
JENR8
Which zombie character do you have? Capsces has some crawling poses for the Markus Zombie (for Genesis 3 Male) that could easily be tweaked for an emerging zombie.
Also the Zombie Run Poses have some climbing out of the ground if your zombie is based on Genesis 3 Female.
Thank you so very much for this. I have both characters and will look into it - Thank you!
If push comes toshove, there's also the option to use poses for the base figures that come close to "climbing out of the ground" and just change the position of limbs as needed... not everypose has to be bought,I've been told...
That's just crazy talk. Crazy Talk!
