Clothing Not Attaching To Genesis 8 Character
in The Commons
The item in question is 'Jogging Bodysuit for genesis 8 Female(s) by Lilflame'
The issue im having with it, is that it doesnt attach to the character model, even if i attempted to attach it to the default Gen8 model it doesnt work; ive even tried with legacy models and I still get the same result. I've tried reinstalling the item and it doesnt fix the issue.
If anyone knows why I'm having this problem please let me know.
Try this.
Select your G8 and then double click the clothing item. Item should autofit (but might not). Im assuming that this is what youve already tried.
So..
With G8 already loaded, load the clotihng item, select the clothing item. Then you will want to right click on the item and select "fit item to". Select G8 and it should fix your problem.
