Epic Skydomes: Cloud Haven HDRI crashes DAZ during rendering
I'm using DAZ 4.11 beta and I've tried to render a basic Epic Skydomes: Cloud Haven HDRI setting, but it crashes Daz after a few seconds. Anyone knows what could be causing this? Thank you in advanced.
  • What are your system specifications? Do other HDRIs work?
  • Thanks for asking. I should had been more specific. I have Windows 10 Pro 64-bit with x64 processor, 8GB RAM, Intel i3-2130 CPU @3.40GHz.  I have Daz' Render setting as NVIDIA Iray. I go to the Products tab > Props > Landscapes, then select "Epic Skypdomes: Coud Haven HDRI, Environments and any of the styles. The sample camera gives me the backside of the scene, so I switch to Perpective View. Without adding anything, I just hit Render. I just realized, that the first time I render it, everything is completely black, then the second time, that's when it closes DAZ.
    Other HDRIs work, this is the only one that it will just shuts down Daz. I don't get any type of warning, it simply closes Daz Studio.
  • Okay, I just ran it using Daz 4.10, and it worked fine. I went back to Daz 4.11 Beta and tried using the "Render-Setting" and then added the props afterwards and it worked. So it seems the issue is when selecting it from the Environments in the beta version.
    https://www.daz3d.com/epic-skydomes-cloud-haven-hdri
