About Content
michaelxm_a1dddd836b
Hi everyone; I recently downloaded the new DS. However there was a separate download for the content. I used the DIM but it would not install the content file. Is that no longer neccessary? ..or if so., Do I have to install it manually.. and of course where does it go? Because I don't see any folder named content in the program. Thanks
Well, the content isn't necessary in that the application will run without, and for some purposes you may not want the figures, but not having at least the Default resources is going to be very limiting. Do you get an error when you try to install the content? If not, what is happening?
Hi Richard, the actual file name is: Default Resources for DAZ Studio 4.9 But when I try to use the DIM option, it pops up and says: The account referenced is not setup in install manager. Other things such as Daz Studio (even the new beta one) installed just fine... So that is why I downloaded it manually,, But as I said.. I don't know where it goes.. I did find similar files though in the My Daz 3d Library..but no folder titled content.. nor those 2 dsx files with it..
Never mind, Richard.. I think I see the problem now. Apparently the 3D library is the "content" because I see the same subfolders there. It's just simply no longer titled "content".. so you can delete this discussion if you wish. But thank you for stepping up to help me out :o)
