Clothing morph question (or lack there off)
I found a nice set of active wear that i like to use. However i noticed that the top doesnt have any morphs. Is there an easy way to add them or do i need to use a different piece of clothing that has the morph i am looking for.
Hmm as im writing this i may be abe to add fit control and see if that gives me the desired result.
  • If it's something simple, you can try using the DForm tool and then turn it into a morph (More about that here). For more complex morphs, you'd need to take the outfit into a modelling program such as Blender, 3DS Max or Maya and manually change it. You'd then save it out as an OBJ file (or other compatible format) and import it as a morph. The latter is far from an 'easy' option, especially if you're unfamiliar with the software, but it does give you the most control and the best results.
  • I want a 'reveal breast' effect which is proble in the range of complex morph. My skill level in modeling programs is quite low. I have a little bit of Autocad experience but not much.
    However i wll do some reading regarding the DForm tool
    Depending on the piece of clothing and how it is made it might also work to use dForce and primitive handles to get it into the wanted position.
    Great pdf about how to use dForce for stuff like that in this thread
  • The clothing piece is a sport bra/top. The effect i want to create is hooking her finger under the top to expose a breast. Somethign like the file i added.
    178 x 177 - 6K
  • Zev0Zev0 Posts: 7,122
    edited September 2018
    You could also try Fit Control. It has that morph for clothes. https://www.daz3d.com/fit-control-for-genesis-8-female-s
    2000 x 1066 - 264K
    Post edited by Zev0 on
    Yes the second one on the bottom row would be perfect. I will try that. Thanks.
  • It worked (with fit control) So happy now!
