Changing the type of morph to Pose
pedrofurtado21
in The Commons
Hello Friends !
I'm currently working on a new project where I need to create Facial expressions, However, it seems that the type section isn't working properly.
The thing is I was using the Daz Studio 4.10 version and everything work fine even the problem I'm having now wouldn't happen but then I change for the Daz Studio 4.11 , but I was having problems to import meshes back to Daz Studio so I came back for the 4.10 version, and there was when this problem came up .
Is there anything I can do, or I'm doing wrong?
Is the Content Management System running? If not, your Smart Content pane and the Categories/Products list in the Content Library pane would be empty.
i recently had the same issue where the options in the 'Type' category were missing. while investigating i found that the CMS was no longer working, and would not 'boot up'.
this was also just after updating DS to 4.11. there may be other ways of fixing the issue, but i ended up 're-imaging' my C drive to a recently made 'Drive Image' which sorted the issue for myself.
it may also have been caused by a recent Windows update( i use Win 7 Ultimate ), so rolling back a few weeks also removed recent update 'roll-ups'
No is not working :( What could I do ?
Is PostgreSQL installed? What security software are you running?
Perfect!!! I instaled PostgreSQL and is working very well , thank you very much!
See - I told you the forum folks are smart! Never hesitate to ask questions here. Many of the people here have been doing 3D content for years and years and have a lot of knowledge to pass on if you have any problems come up. :) I wish I had been able to help more, but I'm so glad you got an answer to your issue. :)
