Blue around hair when rendering V8 Please Help
for some reason, I have looked, I am getting blue skin around the hair when Rendering, does not how up in preview mode
Image removed due to nudity
Post edited by Chohole on
Hi there - you may get some more help from people if you post some example images so that we can better understand your problem.
I’ve noticed this happens sometimes when the skin translucency is very high, as it is with the default V8 skin settings. There appears to be an interaction between the hair and the skin. You could see if the hair has a morph to expand the scalp slightly so it doesn’t overlap the skin so closely, or try lowering the skin translucency to see if the problem goes away.
thank you
Nice gallery Redz, I like the pregnant one good realism and emotion in it. My sister had a 13# baby also
Here is a picture of what is happeniing, I am so frustrated. I may not know how to do what Redz said, so I mabe missing something
Image removed due to nudity Daz 3D Forum ToS #bullet point 1
sorry about the first picture here is on g rated
What is the name of the hair you are using and are you rendering in Iray or 3Delight? Is looks like a problem with the hair cap.
Undane (sp) but most of the hair does that
Iray
This is Victoria 8 wearing Udane hair with default materials rendered with the default Iray settings. I don't see any green.
Perhaps you could eliminate one thing at a time. For example does this happen only with the character you are using, or with the default Genesis 8 female shape. Does it happen when you apply a different Genesis 8 skin? Have you altered the Udane materials in some way?
