My render is just black image
OnieOnie Posts: 20
Hi,
I tried to search in forums cant see any. Below is my setting:
I render before, it was ok as second picture.
Why is it ok sometimes and not most of the time?
Where do i go wrong? lighting setting are the same.
Thanks in advance.
cheers
  • Richard HaseltineRichard Haseltine Posts: 111,399
    Check the log for errors - go to help>Troubleshooting>View log and scroll to the end, just after trying to render. I do wonder if having the render mode set to Cartoon may be part of the problem - only the default DAZ Studio shaders have support for the toon mode..
  • AJ2112AJ2112 Posts: 1,417
    Render settings > Advanced > render engine > make sure 3Delight is selected. One time I selected scripted 3Delight my renders were black image.
  • OnieOnie Posts: 20
    edited August 2013
    Yes, thank you for pointing that out i will double check it next time.
    But it is true sometime it is ok sometimes it is not.
    Thank you for pointing out the cartoon :-) i did the mistake,
    notice it after and render again.
    i just bought LUXUS and have problem with setting
    cant seem to find the luxrender.exe file.
    Thank you all
    Post edited by Onie on
    LuxRender needs to be downloaded and installed separately - Luxus is a bridge between DAZ Studio and LuxRender that does a lot of the conversion work for you, but it isn't the renderer itself. http://www.luxrender.net/
    ow ok. Got it. thanks
    i really feel than 3delight and LUXUS rendering have their own moods and mind.
    Perhaps depending on the lights :-). Now my LUXUS rendering black
    (before was beautiful image render) and 3delight rendering so fast in seconds.
    Touch wood i like it like that.
