Genesis & Genesis2Female Clothes how to fit?
Hello,
i tryed to Dress up Genesis (V5) with the Bike Girl Cloth, but it doesn't fit right.
BUT before i let the AutoFit Tool do the work it looks fine, only if i Cancel the AutoFit Tool or if i let it convert the Cloth it looks ....
Image (Before) Shows the Cloth before AutoFit
Image (After) Shows the Cloth after Cancel or AutoFit (Unsupported (No Genesis2Female Shape to select there) / Pants > Tight)
What can i do to Fit the Cloth like Image 1 Shows ?
Thanks for help
Yandris
Are you trying to fit a Genesis 2 item to Genesis, if so, it works the other way around, not from Gen2 to Genesis.
http://www.daz3d.com/genesis-2-female-clone-for-genesis
There is this in the store, and I think that is what it is for.
I have seen the product, but i thought / i think it must also go without the product because the clothes fit so before the AutoFit Tool. Unfortunately, the clothing is always unfit as soon as you go through the Tool or Cancel it.
You could try loading the clothing without attempting to fit at all (deselect Genesis and load the clothes). That might be what you're seeing in Image 1 (it hasn't tried to fit them yet). Then you could parent them to the figure...of course once you pose V5 you might run into trouble with the clothing.
Or alternatively load them onto Genesis 2 Female, morph and pose Genesis 2 Female to match (or as close as you can) your V5 figure, and then make G2F invisible.
I expect SickleYield's clone will give better results than either of those methods, but they might be worth a try.
You cannot currently use Genesis 2 items on Genesis 1. A clone shape is in the works to allow this, but until it arrives what you want is not possible. You can use Genesis 2 Female for now, if you want to use the clothing, though obviously it might be a bit basic if you don't have any other products for her.
Edit: Never mind, I didn't realise someone had already posted the Genesis 2 clone link. I'll go lie down now...
Yes, yes it is. :-)
