Nyo Hair crashes DS 4.11 when dForce simulation is used.
Anyone else noticed this as a problem? Nyo Hair (even when it is the only object in the scene) causes DAZ Studio 4.11 to crash when a dForce simulation is initiated. Nyo Hair doesn't even have a dForce modifier.
If you have Nyo Hair (Artist: Daz Originals Crocodile Liu) and are running DS 4.11, I'd be grateful if you would try running a dForce simulation in a scene containing the Nyo Hair figure and let me know what happens.
It does have dForce, although not mentioned in the product title. The readme says "* dForce settings are subtle settings for most head twist and bend poses and not intended for extreme head movement poses". I just used it a day or two ago in DS 4.11.0.196 without problem. I ran simulation, but didn't see much happen with the hair. It is indeed subtle. This is the render.
Thanks for the render and the info. I didn't see the dForce simulation parameters in the Surface Tab... I'll look again. However, Nyo Hair does reliably crash DS4.11 (on my system) everytime I run the dForce simulation. I will have to submit a bug report.
