Banging my head against the computer here, How do you get Blue Planet Orbital view to work in IRay?
billyben_0077a25354
Yep, I am putting knots on my head. I picked up Rayn's beautiful Arachnid Class Transport as a Smuggling Ship for a comic I want to do. I already had the Blue Planet Orbital View by Aako but ahve never used it before. Tried to use it and when I went to render, everything went black. What I want to know is how do I convert it to Iray then save it for further use (not having to convert it every time I use it). I know I will have to convert the planet andf stars over to emisives but not sure how to do it. I have tried converting items before using Iray shaders with mixed success. The emissives always give me fits. I hope we see some more IRay ready Space HDRI's. I already have HDRI Space but plan on picking up omore during the PA sale.
You can use the Iray Sun-Sky Only light, set Exposure Value to about 14. Nor sure if the stars can be made work, so I've disabled them and everything else except blue_gradient, atmosphere, clouds and ground here. If you apply Iray Uber shader to them you can make further adjustments if necessary.
Then I've used a starry sky backdrop from here:
https://www.deviantart.com/sambees/art/Starry-Sky-Stock-102324102
You can also use Scene Only and use a huge plane mesh light shining down on the planet, it gives a different effect and the possibility to adjust the light direction. See render 2.
Just save the whole scene after conversion.
