Where do I find the log file?
I'm getting an error message in Daz 4.10.0.123. It's referring me to the log file, but I can't find where that is. Which is sad, because I've been doing Daz Studio since Jesus lost his sandals. Sigh. Any clue?
  • jcbunnjcbunn Posts: 271
    should be
    C:\Users\Damsel\AppData\Roaming\DAZ 3D\Studio4
  • namffuaknamffuak Posts: 4,457
    From the menu - Help -> Troubleshooting -> View Log File
  • namffauk nailed it... but once you find it... useless
  • kerrykerry Posts: 74
    A new camera magic user having an issue here.
    My first two uses went great but today I'm getting persistent errors that it can't load the script and to check my log file which was not very helpful, every time I click on the product.
    Tried good old on and off again, tried uninstalling and reinstalling, watched the video several times to see if my process was the issue and apart from accessing via the script I'm not doing anything wildly different.
    Any advice is appreciated.
    I did set up the script menu btw, Daz just loaded the workspace without it.
    1262 x 455 - 87K
  • felisfelis Posts: 6,037
    Which paths do you have defined for Daz Studio content?
    And is the file at the listed path?
  • ZomZom Posts: 33
    This happens a lot lately, especially after using Recent Files, and the Log File is useless when you don't know what you're looking for and why...
  • Hashtag, #MeToo I just uploaded my scene in the gallery. I forgot to add something I wanted to, then I also get the error. I've got my text (*Thank you JCBUNN) but yes, Je'ne parlez pas text log speek.
    txt
    txt
    ldaz3d og.txt
    1024K
  • Richard HaseltineRichard Haseltine Posts: 108,967
    The entry
    2025-03-14 19:43:58.685 [INFO] :: 	Json Parser (3938525,0): Unexpected end of file in object.
    indicates that the file did not save correctly - it is truncated part-way through the details of some part of the scene data and so can't complete loading. That could be a bad marker, due to a compression issue (in which case you might be able to recover the file with an archive repair tool) or it could literally be cut off (in whichc ase there is no hope). Do you have a previous version of the scene, explcitly saved with a different name or from a back-up service/utility?
