body hair for CC Foster (genesis 8 male)
Having trouble getting the various body hair (from CC Shave this body hair for Genesis 8 males) to work with CC Foster. Poke threw on frount of the thigh - but not showing at all on the back side. Using DAZ 4.10.
Any suggestions on how to get this to work??
I don’t own the character but I suspect the problem may be with the HD morph. If there is a separate dial for the HD details, you could try dialling out the autogenerated morph in the fitted hair products to see if it helps.
The HD isn't separate unfortunately. Are you using shaping morphs on the hair? Or any other characters/morphs? Is it just the leg hair or are other portions giving you issues? The hair on the back of the thigh is definitely less dense than the front by design. Unlike the chest hair, it loads in long and you have to dial out. The default blonde is also more difficult to see in a lot of lighting setups because you don't light the backside as much as the front usually. I'll follow this thread in case you're still having issues.
