Victoria 4 base not uploading
OnieOnie Posts: 20
edited July 2013 in New Users
Hi,
I left my computer with Victoria 4 base (had no problem locating it the first time)
with Darkwood clothing for few hours, when i come back Daz Studio ask me to
send report on bug, my mistake is, i close it without saving the log.
I try to locate Victoria 4 base again, i cant see it in Daz Studio nor open it from
search computer for Victoria 4.
Picture below are the files that i have in my computer.
What is the name of Victoria 4 base file and size file and type file that i should
be looking for?
Just for sharing, it is a nightmare for me, i have problem before with Victoria 5 does
not fit in the clothing Vic 4, tried auto-fit, asset transfer,D-former, in the end smart
lady told me to buy Victoria 4. But now i still have the same nightmare. I don't
understand how the software work, but very very slowly i am getting it.
thanks in advance for helping.
P/S: Sorry guys for the dot title posting, i was quite frustrated with no force to type on
at 5am in the morning. No words could explain my pudding heart
Thanks in advance for helping.
Cheers
Post edited by Onie on
  • fixmypcmikefixmypcmike Posts: 19,702
    Content Library > Poser Formats > [libraryname] > Figures > DAZ People > Victoria 4.2.cr2
  • OnieOnie Posts: 20
    Hi, i look for it already it is not there. tq
    Are you looking for the Base Victoria 4 figure, because what you are showing is the files for the V4 Shape for Genesis?
    There are no 'User Facing (DUF)' files for the V4 Shape for Genesis, there is a slider in the Parameters pane. Select Genesis in the Viewport or Scene pane, go to Parameters > Actor > Female, and you will find the slider to change the Genesis shape to the V4 shape.
    The V4 Shape for Genesis, is just a morph for Genesis, and must be installed into the same library folder as the Base Genesis figure. There is an older figure called V4, which can be found here : http://www.daz3d.com/victoria-4-2-base which is a stand-alone Generation 4 figure. What you have, is just a 'shape' for Genesis.
    792 x 602 - 264K
    edited July 2013
    Hello Jimmy,
    thanks for the reply.
    I got Victoria 4 figure yesterday it was working well, i use this > (http://www.daz3d.com/victoria-4-for-genesis-2-female)
    before Daz studio shut down by itself, and ask to report bugs which i already did to Matis.
    But now i cant open them anymore. My window, like what you ask, is as attached.
    I have no Victoria 4 morph.
    Cheers
    1025 x 655 - 244K
    The item that you bought is for 'Genesis 2' NOT Genesis
    You will need to load Genesis 2, and then look in the Actor > Female tab in the Parameters pane. There are no other files to load, the Product Page says :
    This product contains only new shapes for Genesis, there are no user-facing files.
    If you have installed this item to the correct place, you should see it when you have Genesis 2 loaded.
    Hello,
    Yes it is true, it says genesis but it is actually genesis 2 female, you can see all other figure shaping options is there, Victoria 5.
    I have search all my computers for all the files. tq
    It is NOT Genesis 2 Female, it is Genesis.
    Please see my screenshot below. You must go to People > Genesis 2 Female to load the figure.
    566 x 502 - 145K
    Hello Jimmy, I have to really thank you so much, it is solved. Yeay!
    My pleasure, glad it's working now.
    Hello Jimmy,
    This picture happens, because of you. Thank you!
    1024 x 768 - 2M
    That is a great image, thank you for showing it!
    Well done.
